It is currently Sun Aug 24, 2025 5:28 pm
 Post subject: Rosette opinions
PostPosted: Thu May 09, 2013 5:36 pm
Last Name: Eaton
City: Lamoine
State: ME
Zip/Postal Code: 04605
So I am in the process, a very slow one, of building my first guitar. Im in the the competition for first time builders but am not sure I can make the deadline or not with everything else going on in my limited shop time.
Anyways, I just put together my first rosette and just made something up on a pad of paper. This is the vague execution of the design, kinda veered off track of my original design but oh well. Just curious about opinions on my first attempt at a rosette, my original design. Should I stick with it or should I go with something more traditional? I have a herringbone style rosette that came with my unserviced LMI kit. I am fairly happy with how it turned out but would like some opinions from trained professionals.
If I do stick with this rosette I'd like to add purfling around the inside and out of the pattern. How should I go about adding it? I was thinking of gluing the rosette in place, let it dry, level it, and then route a small channel to fit the purfling lines. Is this standard procedure or should I create a trench that is large enough for the rosette and purfling lines, glue it all together?
Bear with me, this is all very new to me.
Included is a picture of my circle router guide I made up for this. Worked surprisingly very well.
 Post subject: Re: Rosette opinions
PostPosted: Thu May 09, 2013 5:47 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
I would go with your own rosette, Anthony. Yours looks great, and you made it!
Alex
PostPosted: Thu May 09, 2013 6:19 pm
First name: Larry
Last Name: Hawes
I agree with using your own rosette and what's important IMO is size and scale which I'm just learning after making one too big and one too small. Your initial attempt looks a bit large for my eyes but that's only one opinion.
I have a VERY similar circle cutter to yours and it has a very good micro adjustment. What I do is mark the location of the rosette as close as I can with a pencil then begin routing the channel. I 'sneak up' on each edge until the rosette fits, then gradually increase both inside and outside diameters (one at a time) until both purfs fit. Take your time and take very small bites and you should get it to where the rosette and purfs will fit very very snug. I then flood with CA. Done. As always wait for others who know more.
Thank You and Best To All
PostPosted: Thu May 09, 2013 6:29 pm
It's a bit easier to make the purf cuts after, assuming you have the exact size bit to fit the purling...
PostPosted: Thu May 09, 2013 6:30 pm
First name: Zeke
Last Name: McKee
City: Goodlettsville
Zip/Postal Code: 37070
I like it. I do think it's a little on the wide side, but hey design is not my strong point. as far as the purfling I would add it with the rosette. Make a channel large enough for it all and put it all in together.
PostPosted: Thu May 09, 2013 6:38 pm
Last Name: Kincheloe
I like it. Reminds me of milk snake colors :) I do agree with Larry that it's already pretty large, so if I were you, I'd inlay the ring, and then route for the purfling lines, with the outer one cutting away rosette material rather than enlarging it any further.
It will look especially nice after the spruce darkens some with age so the maple shows up brighter.
PostPosted: Thu May 09, 2013 7:18 pm
Last Name: Eaton
City: Lamoine
State: ME
I agree in that it is def wide enough as is and was my original plan to route out the purf channel by cutting away rosette material. But this isn't something I have any experience so I was just getting some helpful hints. Thanks for the feedback so far.
PostPosted: Thu May 09, 2013 7:51 pm
Its best to mill the channel for the outer and inner purfs after inlaying the rosette. That way any imperfection of the outer edge of the rosette and/or the channel itself is routed away.
PostPosted: Thu May 09, 2013 8:20 pm
Last Name: Eaton
City: Lamoine
State: ME
So how do I get my hands on some purfling lines that are that thin? Do I just buy some veneer and make my own?
PostPosted: Thu May 09, 2013 9:41 pm
First name: Tony
Last Name: C
City: Brooklyn
You could or you could find a bit that matches existing purfs. Making your own is cool though.
http://www.CostaGuitars.com
PMoMC
PostPosted: Thu May 09, 2013 9:55 pm
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
Nice circle cutter!
Agree the rosette has a nice design, but maybe a little wide.
I too route the purfs after inlaying the rosette....
PostPosted: Thu May 09, 2013 10:26 pm
First name: Randolph
Last Name: Morris
Hey Anthony, on the wide side or not, first time out, that's a really cool rosette. I say use it!!
PostPosted: Thu May 09, 2013 10:41 pm
First name: Phil
Last Name: Hartline
City: Warrior
State: Alabama
As a new builder myself, I went through several stages to get this right on my first ones. My advice, for what its worth, is to inlay the ring, then cut the purf lines. I tried it the other way, and over and over I would have one spot where the purfling wouldn't go in all the way, and would sand out to nothing. Ended up making several, and even had to order more top material and start over before I got it right.
As for the purfling material, LMI sells some sheets of material that I used. I bought one white and one black. Not sure what the material actually is, probably close to cardboard, which is wood after all. But with this stuff, I could cut strips as needed off the edge, with plenty left over. It bends wonderfully, and is easy to work with. I also used it when binding the outside of one of mine as an accent stripe.
Phil
http://www.oleninstruments.com
"Those who tilt at windmills are only considered insane by those who can't see the dragon."
PostPosted: Fri May 10, 2013 1:40 am
First name: William
Last Name: Holmwood
City: Brighton
Country: England
Really nice rosette. I would stick with it. I would definitely take the advice above and inlay the purflings after.
I am also building my first for the challenge build. There are some really good tutorials on here for making your own herringbone etc.
It's not that hard, just a little time consuming. But you will end up with enough for several guitars so I'd say it's work the effort.
One thing: Seal your channel before inlaying your rosette. ESPECIALLY if using fish glue. I learned this the hard way. gaah
PostPosted: Fri May 10, 2013 4:33 am
Last Name: Eaton
City: Lamoine
State: ME
So when you say seal the channel does this mean the bottom as well? I may be using fish glue as I bought it for this build from Lee Valley. But it seems counter intuitive to seal off the channel before applying glue as I would loose my bonding surfaces. Or am i supposed to just seal off the small walls of the channel to prevent the end grain from soaking in the glue?
PostPosted: Fri May 10, 2013 7:03 am
First name: joseph
Last Name: sallis
City: newcastle-upon-tyne
State: tyne and wear
Zip/Postal Code: ne46xe
Country: UK
make yourself a purfling scraper like Dan Miller viewtopic.php?f=10134&t=38883&p=519439&hilit=+purfling+scraper+#p519439
Then you can make your own binding, purfling etc.
We are all in the gutter but some of us are looking at guitars.
